Archived 1500 RPM and lots of smoke
Archived Truck Won't Turn Over
Archived Twins installed
RBeard
I replaced my VP on the 17th After replacing the APPS in November. After the R&R of VP the MIL light would not go off and the codes 121,122,216 were still showing on code check in trip meter. Drove 250 city/hiway miles this week with no problems except a flat spot just above idle during acceleration. Today I start it and it's missing out and if you try to idle it above 1200 it misses and smokes (white/blue). Not enough power to even start off in low gear. I posted my MIL problem last monday and haven't had time to have an OBD-II scan done. Any ideas???? I'm down and need to get going. #@$%!
Try To Inspect The Battery Cables. Have Had Multiple Trucks In The Shop For Apps Codes And Pump Problems When It Had A Poor Ground. If Any Corrosion Or Cables Are Loose At All Clean And Tighten. May Be Needed To Take Away A Little Matterial On The Cable Side Where The Through Bolt Is So The Cable Can Be Tightened Enough.
Change you Fuel Filter. Do you have dirty fuel???
Do you have fuel pressure?
Those codes do show a failed APPS and a failed VP44.
Filter was changed,Pressure is 14@idle,10@1800rpm. It runs like it's injecting too much fuel to each cylinder(so rich it will barely run) Turbo's spinning,no apparent boost leak,:confused:
