Engine/Transmission (1998.5 - 2002) 150K mi Maintenance Help!!!!!
2nd Gen Non-Engine/Transmission Adding fog lights to 95 Ram
Engine/Transmission (1994 - 1998) single stack
My '01 just turned 150K miles (still with the orginal lift pump) and running like new. What maintenance does everyone suggest I do/have done to keep her running this way. I appreciate your help!!!!!!
KY
To start with:
  • Check the valve lash; adjust as needed
  • Flush and replace brake fluid
  • Flush and replace P/S fluid
  • Pressure wash external heat exchangers (radiator, condenser, intercooler)
  • Replace fan clutch
  • Replace serp. belt
  • Clean fuel pre-screener
  • Check starter contacts; replace if needed
  • Locate all body and frame ground points; clean and reassemble with dielectric grease
  • Flush and replace coolant
  • Replace batteries; my red Optimas are doing great after 5 years
  • Check intake heater relays (search TDR); see grid heater relay replacement for better relays
