AH64ID
Well I hit 15K miles today and had some time to get it done today so the 15K mile service is done.
Fuel filters were the only thing required, but I've always been a fan of an early fluid change to get break in metals/particles out.
I will say that I don't recall seeing the engine mounted canister filter so clean on my 05 after 15K miles and I was running a BF1212 before the OE filter. The dogbone filter tool from Geno's was a big help.
There is no doubting the reports that the OE gear lube isn't great. The rear fluid felt thin and was VERY dirty.. no you can't always judge fluid by it color but compared to the front there was no comparison. It was also a little gritty. If you have more than 15K miles on your truck and haven't changed the gear lube you should!
The front diff and xcase looked about how I expected, lightly used but not bad.
The trans fluid looked brand new... likely this change was the least required, but I was already doing a service. 7.2-7.3 quarts, just as expected.
Not trying to get into an oil discussion.. but the EZ Pack's from Amsoil are AMAZING!! Easiest xcase and diff fluid filling I've ever done.
All in all not a bad afternoon in the shop with a fire going and a beer open.
