I went to the 12 wastegated housing from the stock 18. Talk about a difference. It required re-learning how to drive the beast. There is, once you are moving, pretty much no lag. Although it takes time for the turbo to spool, at anything over 10 mph, the turbo will produce the high-pitched whine of full bore power almost instantly. Even stopped with my foot nailed on the brakes, stabbing the pedal means you start hearing it boost almost immediately, even not moving.
Once I change to the PW injectors, it will respond even faster. BTW, mashing the pedal at a standstill produces NO visible smoke at all, but the truck will begin to accelerate very strongly at about 1/2 to 1 truck length and you can hear the whistle.
I also noticed that when I still had the 18 housing, going from stock to straight pipe resulted in considerably faster turbo spool-up.
