160hp pump w/ tst#6 slid forward
Steering Wander TSB
NV 4500 question
I have a 160hp pump with the tst #6.
If i was to slide it forward, how much should i slide it? Is this going to hurt anything. Is there still hp left in the pump?
thanks
Adam
"POWERSTROKE THIS"
Adam Harman
95 auto red and white #6 tst , eagle alluminum wheels. Stright pipe, Goerend Converter, vb work, 15 degrees timming,ramsey 8000# rear mount winch. Still BOMBING
Go for the slide. I've got mine all the way forward on both our rigs with no problemo. After I finish my transmission mods I will probably go with some 215 injectors to ease off some of the back pressure on the pump. With the number 6 slid all the way forward I dyno'd 266. 9 at May Madness #ad
My version of the Burger King ad: "The bomber says, 'Free horsepower is alot like LOVE'" #ad
Daniel
Wife's truck:
95 2500 SLT Laramie 3. 54 automatic JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N chunked, AFC adjusted, "gutless" cat, Geno's dual EGT/boost gauge, TST #6 plate slid all the way forward, AFC housing slid all the way forward, silencer ring removed
My truck:
95 2500 SLT Laramie 4x4 automatic, Geno's dual EGT/Boost gauge, Dodge cat test pipe (I'm still testing hehe), Geno's muffler eliminator pipe, AFC star wheel adjusted for smoke show, TST #6 plate slid all the way forward, AFC Housing slid all the way forward... let the fun begin!
"Only thing better than having a Cummins is having TWO Cummins"
[This message has been edited by danandme (edited 05-24-2001). ]
Mine has the stock plate but same year truck. I slid mine around today. It looks like you can slide it all the way forward or all the way back without hurting anything. It changes your fuel/air mix and the farther forward the more fuel she gets. If you go too far, you may find it smoking more than you like.
Guys,
I have always left eh AFC housing in it's stock position which is nearly all the way back. What effect does sliding the housing have? Seems like moving plate and housing together might counteract each other???
Bill in Bend
Bill Littlefield
'95, 2500, 4x4, 5sp
With my #4 plate in the stock position I could only use full throttle for v
ery short bursts. With the plate moved back . 040 the egt's are pretty easy to deal with.
For a wimpy 160 pump my truck has "enough" power-wow! never thought I'd say that! With camper etc. it weighs close to 10k and will still go over the grapevine on I-5 at 85. (Just an experment you understand).
About the only engine mods I'm still planning are an ATS manifold and I would like to try a 16cm housing, but the 12 sure works well with the combo I'm running.
95 2500,std cab,4x4,auto by Dunrite,TST #4,AFC spring kit,Pier's gov spring kit, timing @ 15*, 215 injectors, Walker muff, 3. 54,Diprocol gauges in cupholder slot, K&N,Optima reds, Valentine One radar deflector,Diamond utility bed, Firestone air bags, custom 52 gal aux tank under bed.
New Toy- Yamaha WR250F -WOW!
Originally posted by Bill Littlefield:
Guys,
Bill in Bend
Bill, you always want to slide the housing as far forward as you can, regardless of where you position the plate. It doesn't counteract the plate slide, although I can see why you would think that. Don't really know why it doesn't, but it doesn't.
Daniel
Cooker,
This is what Ted J says in his cam plate instructions about sliding the AFC housing foward.
"Sliding the AFC housing all the way forward minimizes the fuel holdback from the AFC link at low boost and also allows the governor rocker greater rack travel and more fuel delivery. "
The above was written assuming your new high performance torque plate in the same position as the stock one was, like the directions say to install it, so back to square one. #ad
[This message has been edited by HEMI®Dart (edited 05-26-2001). ]
