I too changed my housing to a 16cm. And like previously stated because I already had an 18. 5cm housing the change was a bit subtle for me. It does spool up quick though and I get another couple PSI at most. The 91's had a bigger housing than mine I think it was 21cm. In this case you will see a difference.
You will find the number cast right on the large 'compressor wheel' portion of the existing housing, at the top facing the rad, I think. Thats were mine was anyway.
93. 5 D250 4X4,HD Spring Pkg, Rancho 7000's, Rear Swaybar,Dual Shock Front Stabilizer,BD Injectors,31/2" Mandrel bent exhaust,16cm 'Hot End',Modest Pump Tweaks/Timed,K&N Air,Isspro Pyro,Tach,transmission Temp,Auto Meter Oil Filled Boost Ga. , 3:54's, 4 Speed Auto, Clubcab, Aftermarket Reclining Buckets w/ctr Drop Down seat/console, Black over Silver, 21psi,285-65R-16's,American Racing Clear Coat Mags, Amsoil 15W-40HD Marine,12,000 lb. Warn Winch,KC Spots. 97,000 Kms.
