OK all
Now that I have the PW injectors put in, I need to replace the housing to get rid of the turbo lag at take off. If I order a new 16 cm housing, will it simply bolt in with out any other mods or will I need to make some changes? I'm wondering about the down pipe out of the housing. Do the housings come with all needed gaskets? ( the injectors did not come with all things that were needed, had to re-use the drain line sealers and the O-ring dust seals at the top of the hold down nuts )
Stan
93 2WD extended cab, Banks Power Pack, K&N Air Filter, PW Injectors,Auto w/4. 10 rear with limited slip, US Gear Exhaust Brake, 31/2" Exhaust, 5K air bags, Boost/Pyro/Tach Gauges, Green/Silver, 146K
Stan
