16K SuperGlide in a Mega Cab
How to repair gelcoat
Classy Chassis Haul-It-All
Hello All;
Just thought I'd post my experiences with my new towing setup. I'm new to the RV world and the truck / trailer combination in my sig is the first time I've towed any kind of RV. Before deciding on a towing setup I tried to do as much research as possible. The majority of which was spent on this forum.
With the short box I knew a sliding hitch was needed and an automatic one just seemed like a smart thing to do. Figured all it would take is forgetting to slide the thing back once with the resulting damage and the extra expense was covered. I bought my hitch through Big Discount RV online (www.bigdiscountrv.com). They wouldn't ship to Canada so I had it sent to Shelby, Montana and I drove down to get it. Even with the cost of the drive down and the taxes when I crossed back into Canada, I still saved about $1000 CDN ($850 USD) versus buying it locally. :)
I am somewhat mechanically inclined so I decided to install the hitch myself. Local dealers quoted me 8 hours in the shop at $105 CDN an hour for the install. Even with the tools I had to buy I saved some money. Now, I will admit it took me longer than 8 hours to put it in. Lets just say the time it took me was a multiple of the 8 hours quoted. You can decide if it 2, 3 or 4 times! :-laf
I had to adjust the measurements in the instructions somewhat as I have a pretty thick spray in bed liner. This is where drilling the 1/16" pilot holes is a real life saver. I drilled several pilot holes to make sure everything was lined up perfect before drilling the big holes for the post. Installing the rear brackets was not too bad. I had the truck up on stands with the wheels off and the fender liners out, I also took the spare down. The worst part was cleaning off the frame rails. When I boought the truck I paid extra for the undercoating to protect the truck as road salt in the winter here can do some real damage. Problem is, the brackets were designed to be put on a clean rail. The undercoating is some kind of tar that they spray on and it took forever to clean it all off. #@$%! I still have a stain on my driveway from all solvents I had to use.
The front brackets were not so bad to get into place but an extra pair of hands to hold bolts in place while you screw on nuts is a bonus. My 6 year old son was more than happy to help out. My biggest peeve is with the instructions. In the first few pages they have a chart that lists various torque value for different size bolts. So when I was torqueing bolts up I used thier list as a reference. On the rear brackets this did not present a problem as all fasteners go into locations that will not allow the truck frame to crush or the brackets themselves to bend. Not so on the front. When I torqued the bolts on the front brackets to the value specified, it bent the brackets. I called the SuperGlide tech support guys and he said the torques in the chart are for reference only. You're only supposed to torque the nut down until the split washer is flat. He said they get lots of calls about bent brackets. I asked him how long it would take to send me replacement brackets because thier instructions are not clear and he said the wouldn't. He said to torque the remaining bolts the same and everything would be fine.
I now have about 7500 km (4660 miles) with the rv in tow and I love the whole setup. Bottom line, would I buy from Big Discount RV again? Absolutely. Would I buy the same 5th wheel reciever? For sure. Would I do the install myself again? Yes, but only in a heated garage. My driveway in early March was a little cool for my liking. Would I help someone else install one? Yep, as long as they have a garage!
I forgot to mention the installation of the capture plate on the king pin box of my trailer. The capture plate is what makes the receiver pivot and slide as the truck and trailer move in relation to each other.
My pin box was the right width but was not long enough front to back. I had to buy an extra kit to modify my pin box. The kit consisted of two metal plates cut and bent with holes drilled to match the capture plate. The plates are a little long in places to allow use in multiple applications. You just have to trim off the excess as required. I then found a welding shop to weld it all together and I was good to go. I painted the new bits after welding and it looks pretty good from 3 feet away.
My only complaint with the kit is that the holes that are predrillied in the smaller plates did not match up exactly with the capture plate itself. They were close, but I still had to modify the holes in the smaller plates to allow fitment of the capture plate.
Bottom line, would I use the same capture plate again? Nope, the Pullrite website shows a new "Quick Capture" plate design. Apparently it just slips over the pin box and is held in place with four set screws. I bet my RV dealer would have prefered this route when I did mine. I had to leave the RV at the dealer with no pin box on it while I had mine modified. It meant he couldn't move it till I brought the pin box back to him a week later.
Like you, I also installed mine. The first time was on an '04. 5. It took the better part of a day. I spent a lot of time making sure everything was lined up before drilling the large holes in the bed. Then I traded for a new '06 and swapped the hitch. It took less than three hours to install this time. After making the preliminary measurements, I put a light under the truck and could look down through the pilot holes and see the bracket centers. It was easy to adjust the hole centers and made everything go much faster. My brackets also had a little bend in them after tightening the bolts to the specified torque, but I don't think it is a problem.
I am surprised that they provide torque numbers "for reference only" though. I assumed that their torque measurements were based on proper engineering analysis and testing. I have used mine many times and am still very pleased with it. I see that Pullrite is now selling a dry graphite spray-on lubricant for the way-tubes which is supposed to be better and cleaner than coating them with grease. I plan to try some soon.
Jim
Hi Axion:
Thanks for sharing your experience. I'm considering the option of a 5er versus a TT and will have a similar truck to yours.
Much appreciated,
Brad
JimBob24;
I think the numbers they quote in the instructions are the proper values for each grade and size of bolt. But to be honest, I did not double check them with other reference sources. By reference only I think he meant not all bolts in the install are to be torqued to that value.
When I was ready to check a pilot hole, I covered the top of the bracket with masking tape, put it in place, snugged the bolts and then pushed the drill bit down through the hole to pierce the tape. Then, when you pull the bracket you can measure exactly how much adjustment is necessary.
Having to spray the way tubes with grease is about the only downside to the superglide. It kind of makes a mess. Maybe the dry graphite would be better.
I won't say I'll never have to do another installation of this type but I hope to have this truck for a very long time.
BBeck;
No worries, sharing experiences is what the forum is all about. I have learned tons about my truck on this forum. Its nice when you can give something back.
That is great info, even though I am having my RV dealer install mine since I am deployed. He gave me a decent enough price for the install. I ordered the 18K Superglide, would have got the 14K but wanted the little extra margin of safety, I know that I will probably never need it, but it is nice to have. Scotty
