Engine/Transmission (1994 - 1998) 175 Pump Max HP??
2nd Gen Non-Engine/Transmission Still more steering problems
Engine/Transmission (1994 - 1998) valve adjustment
Right now I'm sitting at around 270 hp. I have a stock plate slid forward. Timing at 19 btc. 370 injectors. 3k gov springs. If I had a 0 plate what would my estimated hp be?
I have delivery valves but not installed. I'm thinking about getting a 14 sqm turbo housing to breath a little better.
Remember Its just a 175 hp pump. Just wanna know what it will max out at.
Maybe 500 hp or so, unless its been converted to a radically modified "stupid" pump like PDR sells.
I think Joe D posted once dynoing a 175hp 5spd at about 400hp w/#4, 370's and a 16cm2 housing and likely other tweaks he may/ may not have mentioned! :)
Good luck
Andy
For comparison you can see what I have. With the #10 I dyno'd 404 and 899 a month ago. I dropped a #0 in and haven't dyno'd, but it is a hot for JR's little schwitzer that I have in now. With a bigger turbo and this plate, I think I would be real close to 500. I might be mistaken but I think it is possible. I also think that is as far as I can go without major pump work like mentioned above and bigger turbos or twins.
Thomas
