Slow acceleration or lack of power while towing or hauling a heavy load.
This information applies to vehicles equipped with a 5. 9L - 24V diesel engine built before engine serial number 56587297 with a date of engine manufacture of May 5, 1999. This information is available on the engine data plate, which is located on the left side of the engine, affixed to the gear housing. There may be a condition of low power or slow acceleration when towing or when hauling a heavy load. This software change, to the Cummins CM551 diesel engine controller, will increase engine torque. Some 1998 BR vehicles equipped with a 5. 9L - 24V diesel engine may already have the latest software revision. Verify that the ECM is at calibration level 98T17 (p/n’s 333034303J / 333035303J / 333036303J / 333037303J). If the calibration level is 98T17, then this TSB does not apply and further powertrain diagnosis may be required. This bulletin involves selectively erasing and reprogramming the Cummins CM551 Engine Control Module (ECM) with new software (calibration changes 98Cal T17 and 99CalT8B). There is no change to the JTEC PCM software.
Does your truck fall within the serial number range?
