185 PowerWagon injectors in 4bta
gauges and dash pods
Peeling Paint
I have a set of 185 PowerWagon injectors (Bosch part number #0432133875) with the stock retainer rings from my '93 W250. Will these injectors with the retainer rings from my 5. 9L fit an '86 4bta engine, or will I need to find an adapter to make them fit? If I need adapters, where can I find them? Thanks
Tom
1986- 4BT should have a 9mm injector bore, so you will need the 7mm-9mm brass adapters to run the 185's. We carry the adapters at PDR.
Thanks Mark, that's what I needed to know.
Tom
