Details here: TDR Privileges
I just put in 370s and have a 230hp plate (can someone tell me what # this plate is) and can get an 18cm turbine housing to replace my 12cm. Would that be a good thing to do?
The 18. 5 smokes more and is a bit harder to spool up than the 16. A used 18. 5 should be cheap, though, if that is a big issue. I have some of them laying around, and a couple 21 cm2 housings for masochists. Can you say "turbo lag"
What plate is 230 hp rated depends on which pump you have. The 180 pump = #8.
