19.5 wheel upgrades and TPMS sensors
Best time to sell an RV ?
lmabey
You folks that are running 19.5 with the higher tire pressures where the factory setup was for e-rated tires - does it make any sense to try to keep the TPMS sensors going? I have a controller that allows me to disable the tpms. But i'd rather be able to monitor the tires even thought the tpms light may come on (can't remeber if the light warns you for overpressure situations).
Any Thoughts
Thanks,I also found on the generation IV forum that the operating pressure ranges can be adjusted at the dealer ship
I go with close to the same pressure with the 19.5 Tires.
They don't need such a high pressure, with our load we usually have on the trucks then around 50% of the pressure that is written on the sidewall is plenty enough.
Check out the pressure lists on the Tire Manufacturers Homepage for the adequate pressure.
