I have installed the older type of Dodge cruise control on an '88 Ford 7. 3 diesel F250, a 1971 Baja Bug and even my '89 W250. It works great on the Bug but on the Ford (which is now gone) and now the Dodge the speed drops way off after you set the cruise. There is an adjustment on the unit to correct this but it seems to have little or no effect on the problem. The speed drops off almost 10 mph. I have tried adjusting the cable freeplay also. Does anyone know if these units do not work well using the belt driven vacuum pump as a power source? It does not really seem to me like that is the problem. The resume works well, for example, which I think is the cruise control function which requires the most vacuum power. Any thoughts?
