1977 wilderness 22ft --whats it worth
Angled Ball Mount?
going to look at a couple campers tomorrow... the guy says it`s in mint condition new fridge new tires stayed in a park all it`s life
they are asking 3k for it???
thanks marcel
New refrigerators run $800-$900 dollars. Get the receipt & warranty.
After that, IF the tires are new (check the date codes), and there's absolutely no sign of water entering the trailer, it may be worth $2,000. You know how to look for water entry and dry rot?
If it is "mint" and you get it for 2k, it should serve you for a while.
Regards, DBF
PS: I had a '74. Dry rotted under all the rubber strips on the rear.
thanks for the reply... . it was in mint condition... set up for a/c ... ... . the previous owner had put a new brakerbox ,new water pump..... very very clean... . headed to maine next weekend,Do i have to stop for the scales?????????
thanks marcel
Good on ya. I hope you enjoy it for a long time.
Have a look thru the Towing & Hauling/RV forum on this board if you're new to towing trailers. Lots of good info.
DBF
