I have a 1985 Chrysler 5th ave. It has the 318 hooked up to the 3 speed 904 automatic.
I have successfully removed the old two barrell carb and manifold, I've removed the smog pump and the cats (yeah it had two, couldn't believe it) It now has a duel exhaust system. I installed an edlebrock manifold and a (model #4160) Holly 4 barrel 600cfm with vacuum secondary. i also installed a MSD blaster2 coil, and a OEM distributer with vacuum advance.
The car ran and drove.
Then the computer fried. i was told it was because of the coil. something about the system needs a certain resistance (ohms) well MSD told me that the coil i bought lowered the resistance and fried the computer.
Well i was told that i needed to purchase a Streetfire ignition box to take the place of the computer, which i did.
Now the problems hit. Everything is hooked up proper---no jerryriggin.
The car wont run.
It turns over but will not run. The voltage does drop but not to below the nesscary to run the box.
The problem is, when i remove the distributer and with the coil wire placed near a ground, i can turn the distributer staft by hand, and the coil wire sparks. when i reinstall the distributer and try and start the car, there is no spark.
ANY ideas?
new coil
new distributer
new ignition switch
new carb
new manifold
new exhaust
what gives?
The car wont run.
ANY ideas?
new coil
new distributer
new ignition switch
new carb
new manifold
new exhaust
what gives?
