Well, took it for a test drive.
Issues:
Brakes were replaced, just not the rotors, still has a vibration, Assuming it's your typical warped rotor/not mating properly to the pads
Rust areas include from fender, mid doors and rear quarters. . little patches, I'm sure a little sanding and primer and it can be stopped in most areas. except for the 5x6" rust hole missing on the front... .
interior is missing the radio, funny, I just pull my entire 144db system from my jeep while in MI.
A/C blows "cool-ish". This will need a re-charge and leak fix
Throttle sticks, it's clearly a linkage issue. it sticks just past 1/2 throttle, you can pull up on the peddle with your foot.
the current owner would drop the trans in neutral and then pull up on the throttle, I'm sure it has hit 5-6000rpm a few times. I hit 5,000 while parked
It rides like a Benz, turns well, didn't take it on the highway, due to brakes and throttle issues
Most of these I'm comfortable with in fixing my self. however, the big one:
Harsh vibration all the time, while parked and moving. Not sure if it's a motor mount, or a tuning issue.
motor sounds good, not odd ball noises, definitely quieter then a 12 valve. Odd seeing a P-pump style pump with only 5 lines.
it does pull good once boost kicks in, then you let off and it grabs 2nd and it's a dog.
That's about all my first impressions.
