This may be the best GM truck i have ever seen. Wow, that frame really is wide! Hard to tell without weight on it, but what did your front caster come out to? Plenty of travel to the bump stop for the radius arm without hitting frame?
I like your track bar being behind the axle, wish i'd had room for that. Does it's angle match that of the drag link? Is that a 700 or 800 series gear box, how is it doing with all of that weight over it?
The arms on the sway bar are nice and long. How does it handle? Does the length provide more articulation? Mine is short both on the main arm and the drop links. The drop bars are angled on mine because the bar goes too far back over the axle mounts, makes the truck kick back to center harshly.
How many miles per gallon (converting) are you getting with the Cummins power? Anything you would or plan to change? Your truck is beautiful, looks like a very meticulous job you've done. Black is my favorite color. Must feel great to drive a truck you've built. Far better than anything that's ever rolled off an assembly line. Congratulations on a a real truck.
