One the way home from lunch today, the check engine light turned on and would not go out. The Tachometer is reads fine, the A/C fine, I have oil pressure and the volt meter is reading 14 volts. The water temp is also normal. The radiator overflow looked a bit low so I added some distilled water. (Plan to have the radiator flushed next week after payday, so not too worried about the water instead of coolant. )
I retrieved the trouble codes and I can tell you I hate this process since the 95 is not ODBD II compliant.
I did it a bunch of times to attempt to read the codes. I got a total of 18 flashes and had a hard time with the codes so here goes.
Turn the key on, off, on, off, on, the check engine light is steady for a bit then blinks once, pause, two quick blinks, pause, four blinks, pause, one blink, pause, then five blinks, pause, five blinks and done.
So what has me confused is that the first code looks to be a 12 which says that the battery has been disconnected in the last 50 key starts. I can't remember disconnecting the battery in a couple months so that does not seem right to me.
The next code looks to be code 41 which the manual says is a problem with the generator field not switching, what the heck does that mean?
The last code 55 to close out the code reading.
So what does the code 41 really mean? Is my alternator having issues? It seems to be charging fine. When I turn the key on, engine off, the volt meter reads 12 volts, then start the engine and the reading is 14 volts.
Several months back, I replaced the alternator with a rebuilt one, has it failed on me?
Thanks in advance.
Craig
Thanks in advance.
Craig
