This week I picked up a 1995 F-350 (for a possible Cummins/NV4500 swap) with the 7.5L V8 gas engine and auto transmission. It has a passenger-side fender-mounted starter solenoid/relay, and I have to tap it to get it started. Upon inspection, I found that there was another relay spliced in, that I am not finding in the Chilton manual, maybe something a previous owner added. On the harness, there is a yellow wire tapped into the horn, a blue wire with an inline fuse running to the starter solenoid, and a red and a yellow wire that are both cut. If this isn't stock, all I could think it might be is from an alarm system?
Does anyone know if this is actually a stock vehicle part? Also, should I just pick up a replacement starter solenoid, or is this a user-serviceable part?
