1998.5 Quad, Who should I order replacment rockers and cab corners from?
Replacing rear wheel brake cylinders
Air Bag light…
Forget what company I ordered mine from? I didn't get cab corners. I got rockers; outer, inner and vertical drop from cab floor piece. I found the bends on the outer (visible) were slightly off to the point where they couldn't be properly installed to butt weld to the existing good. I took a slice cut out of a piece I removed and set next to the new and the new was definitely off. I ended up being able to take the new rocker and piece I cut to a sheet metal manufacturing outfit whom were able to re-bend to match.
Have fun
