1st big tow with hx-40
DamAir - any pictures & comments pls.
Bully Dogs newest injectors
i just put a hx 40 on my truck and just pulled a good size load with it. my gcw was around 23k-24k. i don't think the lag is that bad while towing. the only time you notice the lag is while shifting and it's not bad at all. now while drag racing the lag is terrible.
the hx-40 really helped my egt's unloaded, i used to be able to hit over 1700 now i can't hit over 1400.
but while towing with my comp box in the ez setting i had about the same egt's as before. one of the passes i went over is a 6% grade for about 4 miles. i held 6th gear for about 2. 5 miles at 75mph. in 5th gear i was able to hold 65 at the crest of the hill. mileage was 11. 5mpg at 70mph with around 60 miles of unloaded driving. the second leg i went 79mph and i got 8. 3mpg. so as this test i don't think my hx-40 cools much better than my hx-35 did in just the ez setting. i was running 32 psi.
now on the way home a dooley duramax passed me pulling a 26-28' fithwheel camper. it was a single slide so i figure it weighed in at around 8k. now i had about twice the weight he did but he did very well with that trailer. i would just follow him and every time we hit a hill he would slow more than i would. so i would pass him on the hills and he would pass me on the flats. going up the 6% grade coming home i was going 60mph and he was going closer to 55mph.
here is a pic of my load it's a 30' gooseneck pulling a 14' enclosed trailer going to the derby. we took 3 cars and got 2nd,and 3rd:)
jim
Jim... what a cool pic! I would love to hook onto that load and play.
I know that hill out of Helena... its a good one! Man, you have that truck set up to run with the big boys. I miss those Montana hills.
Pretty Cool Huh?
Hey Jim, long time no see.
BTW, it seems like a crime to be from Montana and not "brag" about it in Author section of the post header.
