Chief USA
I did my 1st fuel filter change on my truck yesterday at 10,400 miles. I followed the direction posted on Dodge Ram.org and bumped the starter to prime the fuel filter housing 9 times instead of the 7 they did. I also jumped out of the truck and purged air from the injection pump shraeder valve while the lift pump was running until I got plenty of fuel out. When I started the engine, it died almost immediately and would not restart. I did not keep cranking on it for fear of pushing air into the injectors. I bumped the ignition 11 more times and purged a huge amount of fuel from the injector pump shraeder valve and still had to make 4 crank attempts before the engine would start. This is a limp Di!@ fuel system that is not capable of purging itself. Guess I have a weak lift pump and will be making a call to the dealer to set up an appointment to replace the pump. Next time I am using my old A/C fill hose to purge the pump into a large bottle. I purged it onto a large rag not realizing I had to push out nearly a quart of fuel to prime the system. WHAT A MESS!!! At least I got it started and the fuel filter change under my belt but this is STILL BS!!!!!!
