1st. Gen. headlights and door locks.
4 door crew conversion...Need input
Everyone show your "BIG UGLY RIG".
flathead6
When I try to switch on the bright headlights, I get darkness. Do I need to look at the steering column switch, headlight switch, ... . ??
I remember a discussion several TDR issues back where doorlocks that would not unlock from the exterior were discussed. SEveral repairs were suggested to try before replacing the locks. Anybody remember which issue??
Ive had my lights go totally out on my 92 then come back on going down the road , i never looked into mine because it dont happen that much but i suspect a bad circuit breaker
Check and make sure the harness is not pinched or pulled tight in the steering column, and, your headlights actually have high beams.
The dimmer switch is likely the problem but you need to do some investigation first.
