cdrider,
yes, I tried a scope. No, you can't get where you need to be,
there isn't room.
Tim1,
I agree that the front crank seal needs to go in the cover before
installing the front cover. There is only 5" of space between the
radiator core and the front cover, not enough to swing a hammer.
I used the Cummins clear plastic seal starter to guide the cover &
seal onto the crank snout with my left hand, then started an upper right cover bolt with my right. What surprised me was that
the clear plastic seal guide didn't go on in behind the seal.
My dowel pin was still 3mm down in the bore of the timing cover, but it drove in 6mm more before it was seated solidly in the block.
Then I used a small gouge punch to raise 3 good welts on the
inside of the dowel pin bore, using locktite blue as backup. My
wife's 5" cosmetic mirror was an invaluble tool on this project.
I was able to get to the camshaft thrust plate bolts through the
spokes of the cam gear and to some of the timing cover bolt heads hidden behind gears. None took over 1/8th turn with my
torque wrench, so I didn't pull them and locktite them. Some of
the timing cover bolts, I had to grind down a 10mm boxend to
make it thin enough to get through and behind some of the gears.
I turned the engine over with a home made 3/8"pin spanner
wrench engaging two of the three holes in the cam gear.
Besides looking and thinking, I had two additional parts that
took longer than anticipated. 1) The front seal is hard to get in
the cover unless the cover is fully supported under the seal bore.
2) I need a picture or diagram of all bolt locations behind gears
so that I don't spend as much time rolling the engine over and
looking with the mirror. I spent about 6 1/2 hours on this first
one, but I might be able to do the next one in 3 hours or so.
One interesting consequence of this project is that I got a lot
of dirt out of the H Balancer making my engine noticeably smoother, and the irritating buzz that mine had from 1,000-
1,800rpm is about 1/3 as loud from1,000-1,300 where it changes
into a pleasant drone instead of the buzz. When I have the time,
I want to bolt a heavy bar(maybe 2" X 3/8") across the front of
the timing cover with an adjustable preload screw to see if it will
affect the lower rpm buzz or drone.
Mel
