1st Generation FAQ's
Videos of how to mod your VE pump!
6th Annual Iowa First Gen Meet
Steve St.Laurent
Staff Alumni
Links to Dodge Parts Fiche PDF
TDR Frequently Asked Questions
***500+ complete***
1990 dodge 3/4 ton military truck. Cummins, 6BT- 5.9 diesel engine
1st Gen Stage 1,2,3,4 performance steps.
2nd Gen compatibility in 1st Gen trucks
2ndGen intercooler install
Are there any other differences between the 89-91.5 models and the 91.5-93 models?
Are there differences in stock 1st Gen injectors??
Best tip for New 1st Gen owners/Guys willing to help Threads Merged...
Can I check my Idle speed with no onboard tach?
Can I rebuild the dana 70 rear end
Closing - What happened to the 1st gen market?
Do I really need all those gauges??
Do I really need to use a fuel additive in my Cummins?
Factory Service Manual (FSM) update
Getrag rebuild manual
Governor Spring/VE Info Threads Merged..
How do I fix the transfer case shifter rattle?
I keep seeing all this stuff about injection timing. Is it really that important?
RIP Bushwakr
Robert (Pastor Bob) W. Coe Memorial Services
Turbo help please!
What is a KDP (killer dowel pin) and what is it all about...??
What is the maximum EGT I can run safely?
What is the the max safe RPM without changing valve springs to heavier ones?
What type of fluid should I use in my 5spd?
What was that Part Number for....?
Where can I get a factory Service Manual (FSM) ?
Why do I seem to have so much slack in the steering
Why do my lights and alternator gauge dip when it is cold out?
WHy do older 2wd Rams have so much trouble with front suspension/ steering?
Why does my truck smoke alot when cold?
Won't start after it warms up
