2 110 plugs ?
Enhancements
Ball Joints Revisted
My 01 has 2 plugs one on the drivers side and one on the passengers side. Last year I always used the one on the passenger side, should I use both, what is the one on the drivers side for?
thanks, Jeff
Just curious, where is the one on the drivers side? I never looked for one there as I knew the on on the passanger side was the block heater.
Anyone else have 2 plugs?
I will hhave to look at lunch and see if I have one on that side.
Mike
Got to be battery heaters, one for each battery and the block heater, follow the cables. SNOKING
Could also be an oil pan heater. We had one on a 91 CTD, but it was aftermarket. If it is make sure to unplug it before you start the truck. They don't hold up too well if you don't.
Corey
