2.5" leveling kit?
Best way to get the front coils out?
Help Needed For Broken A Pilar Mounts and Clips
I know I saw a 2. 5" leveling kit in a couple member's sig's. Assuming the kit brings the front of the truck up so it's level with the rear. Master of the obvious right?! Anyways, who sells them? Also, how big of a tire can be run without interference problems?
As always, thanks.
Rancho suspension sells a 2. 5" lift kit . The basic kit comes with a spacer cup on the top of the front coils and it replaces the lower traling arm. From what I remember , it was around $350 including new front shocks. They also have the rest of the kit available with 4 shocks up front instead pf 2 and an add a leaf at the rear. I have this kit on my truck and have 35"tall x 12. 5" wide tires on 8. 25" rims . It never rubs. I used to have 9. 75" rims with the same tires and they would occasionally rub, thats why I changed to 8. 75" rims.
Tuff country
I used the tuff country 2" spacers and they worked fine, try jackit.com. Good luck. Whatever you decide be sure to have aligned correctly by alignement shop and not a crappy dealer.
