2" front lift on 4x4
NEW CTD 600 ARRIVED Today
Towing ? witha new 600, thoughts?
Looking into 2" lift spring blocks for front and the kits come with trailing arms etc. all I want is the blocks, do I need to change the link arms too or ? How has everyone else lifted the front of their 4x4 did you just do blocks or do I need to do trailing arms as well?:rolleyes:
I got mine on Ebay for about $100. Do a search for "dodge ram lift" and buy the Daystar blocks. Not the ones with the trailing arms. They are not needed. Plus you keep the stock ride. I have run mine since new and it is great. 2" blocks almost make it level. Looks good and levels out when I haul the trailer.
Greg
Depends on your tire/wheel combo.
With mine I still need to add a little to at least one of the arms. Most likely the top arm.
JRG
Jerry
Originally posted by Jerry R
fencebulder, how are the bilsteins? Which ones do you have? Are they for a lifted or stock application? Thanks jerry
Jerry,i like em fine. They are the brushed aluminum look type. According to Bilstein their "stock" shock applies to to my application,i. e. 2" leveling kit. Although i must admit the valving on the fronts dosent seem as good as the bilsteins that were on my '02 F-250 crew 4x4. Mark.
