2 fuel filter questions
TST, Smarty stack?
Stock Automatic
1) any recommendation on whose filter to use?
2) on my 2006 it looks like that the top just unscrews on the filter holder, is that correct?
thanks
Fleetguard is a good quality filter alot of us use. You can get them at GenosGarage among other places.
Yes top unscrews... it's a 1 1/8" fitting on top of cap.
Eventually you may want to get better filtration for your fuel. Something in the 2 micron range. Keep reading here and you'll see that stock fuel filtration is marginal at best. You cannot have clean enough fuel on a common rail Cummins. JMHO... :)
AMassaro is right. Geno's has fuel filters for a much better price, $15. 00 per filter for a 7 micron filter. Dealers charge $40. 00 for a 10 micron. So I went ahead and bought 10 filters from them. I figure change filter every 10k miles they will last me 100k miles.
Here's another vote for Fleetguard. I buy mine from the local Cummins house.
Drain the fuel cannister first by moving the yellow lever towards the driver's side. Put something on the ground to catch the fuel/water that comes out. I leave the lever open until I get the new filter installed. That eliminates any vacuum as you pull the cap & filter out.
Use a 1-1/8" 6-point socket to unscrew the cap. Don't give into the temptation to just use a 3/8" extension in the square hole on the cap. It will fit well... it will also break that plastic cap.
There is an O-ring on the cap, so it will be stiff. Just keep turning. They are right hand threads, as you would expect. The filter is attached to the cap, so they will come out together.
Wipe out the cannister (carefully) with a lint-free cloth.
Separate the old filter from the cap. It will take a bit of force. Remove the O-ring from the cap.
Use some of that diesel fuel you caught earlier to lube the new O-ring and install it on the cap.
Snap the new filter on the cap and install them in the cannister. There is a torque spec, but with the O-ring, snug is good enough.
CLOSE THE YELLOW HANDLE!!! (Don't ask how I know. )
Bump the starter and leave the key "on". The lift pump will run for about 20 seconds and re-fill the cannister. Some like to do this two or three times, turning the key off after each time.
Start the truck and enjoy!
Bob
The 5 micron may be fine as a drop in but one has to consider the possibilty of premature blockage on that small filter. Finer filtration (down to 2 micron) will generally require the larger surface area of an aftermarket unit.
I am using the 5 micron filter and it doesnt seem to have any effect on my fp,i get 9. 5-10 at idle and 8-8. 5 cruising. I dont want to loose my warranty by using an aftermarket 2 micron,not until warranty is up. Dodge can replace my injectors if they fail because of dodges failure to use the correct filter.
