Is there any adjustment to make to get the front axle back centered under my truck?
Matt400 said:Just remember under full compression the bump stops may not line up well if you lengthen the trac bar.
PRyker said:Huhh?? I was under the impression that using the adjustable DT trac bar would fix this?? Doesn't everything line up well once you have recentered the axle?
biggy238 said:Leveler kit that is...
And like I said, I did this knowing it would off center the axle, But i've found I just can't handle the chevy look.
PRyker said:Mat400,I would love to install a 2" leveling kit but want to do it right so the suspension behaves and functions the way it suppose to with no chance for premature wear.
Leveling with the OE bar just moves the axle to the left some so the front & rear axles and the frame still trac straight.biggy238 said:I also think dog-tracking causes more undue wear on suspension than the new geometric characteristics created by a longer trac bar.
That is a good question and I may put my air dam back on to see if it helps any.The real question is how leveling affects fuel mileage.
