SSolderitch
the way I see it is and the questions I have:
cons:
driveshaft angle increase
tires/axle moved to rear of wheelwell
caster angle change
more tail down with heavy toung trailer (I am leaning down now - should be worse w/spacers installed)
front end alignment issues with cams?
2" longer shocks needed?
alignment needed after install?
is 2" too high?
pros
more clearence for trackbar knuckle - MINE hits the diff cover & took a piece out of the cover and broke off a cover bolt head.
more height for front drop with added snow plow weight.
more room for larger tires
is 2" just right?
Well I am thinking of adding a set to cure my hitting ploblem, but I would be happer with only a 1" lift, so I would get the best of the pro & cons above. Does anone make one?
Better brands? Cage solid aluminum spacers with studs or the OEM style (plates welded on tube). need input here!
Last? - did anyone try adding a 1/4 shim plate above spring & one on the mount to get 1/2" with the factory mounts? This is limited to factory studs and inner tube length. (I can get any shape precission cut/welded at work) or has anyone cut/weld/modify OEM ones?
Thanks - I want the truth - good or bad.
cons:
caster angle change
is 2" too high?
pros
is 2" just right?
