I have received a number of e-mail regarding the 2" lift that I had done to my 96 2wd Ram. As some of you know, there are not alot of options out there for doing this as they can not handle the wieght of our cummins. I went over to the shop that did the work today, as they still are waiting for the rear bolts to install the blocks on my rear end. When I get everything done I will post some pics of everything. The lift was achieved without any modification to the stock A arms, which means it doesn't cost an arm and a leg. They got the lift by simply installing a larger spring. This originally got me 2" but I'm thinking after everything has settled in it is more like 1. 5". It's not alot, but it does pretty nice, and when you couple it with the RS9000's, the ride is much smoother
. The company, Fabtech, is no considering making an actual spring kit with the its own part number, largely in part from interest generated here on this site. I was hoping to get some better engineering into it to keep the lift at 2", preferrably 3". I have installed 265x75 tires and it fills out the well nicely. (All you 4x4 with 315's please keep quiet
I have put almost 1400 miles on it since the install and have had no alignment problems at all, although it does need to be readjusted from stuff settling in.
Those that are interested in having this done (So Cal area) or ordering the parts so you can do it yourself or have a shop do it are encouraged to call Aggressive Suspensions, Fullerton CA. (714) 870-9422- Ask for Darren Let them know of your interest in an engineered kit, as he thought there wasn't any market for it. I told him that's becuase he didn't know of the TDR!!
Cheers-
Kevin
Cheers-
Kevin
