I wanted better filtration so I borrowed an idea from "Superduty" on another forum and made it fit my truck. I had to come up with a way to mount it to the linkage bracket since the area below it was about the only place with enough room to mount the filter and it's mounting plate.
I used a piece of 1/8'' plate steel and mounted one bolt through a hole in the linkage bracket and into the filter mount. This ended up being suprisingly solid. The filter and it's mount are both Fleetguards.
I also mounted a fuel pressure gauge on the output side of the filter. With the Walbro pump, I'm getting 18-20 psi to the CP3.
__________________
__________________
