Details here: TDR Privileges
Will ecu off 305/555 work on 325/600 to get mileage back? If it does, will TST off 600 still work. I know I will lose power by switching ecu but it would be worth it to regain 18+ mpg Three injectors and reflash best is still 16. Have 21000 miles on clock. Dealer ok'd if it works.
I believe the ECUs are incompatible. Big difference in the ECO coding. The 625 has a much larger program and thus needs more RAM. Maybe the hardware is the same though.
The ECU's are VIN specific. When you install the new ECU it checks the VIN from another module (cluster, PCM) and if it does not match, the truck will not run. The stored information has to match.
