2 Questions
370 diamonds
Transmission lube filter question
I HAVE A FEW QUESTIONS... ... 1) What is the max boost psi supposed to be on the 2001 cause I have 3 different Autometer gauges when installed (not at the same time) max out not the same. I am trying to see which one is the most correct. One reads maxed at 17 the other 19 the other 21.
2) Where is the drain plug for draining the radiator because its time to drain some green stuff!!:cool:
THANKS
