2 Questions
Who's using Delvac 1 (5w-40)
What is the limit and why????
I got my jake exhaust brake, it came with a dash mounted switch. I called B&D to price a switch for the shifter-$45. Are these THAT hi or can I get one some were Else?
#2
I would like to take my map sensor out to see if needs cleaned. I don't have a socket the right size. Can any one tell me?
You can always make one.
Description: At 3 o'clock off the steering wheel is the standby/off button for the exhaust brake controller. At 2 o'clock off the steering wheel is the switch for the exhaust brake that changes it from normal operation (foot off the throttle and clutch) to on command using the thumb switch on the shifter (Hurst T-handle shifter with thumb switch), this activates the exhaust brake on command when pushed. Underneath the handle are two switches for reverse lights. One set in the rear below and behind the bumper, the other set underneath the cab pointing just to the outside of the rear tires. On the 4X4 housing, is Scrat, and my US-Gear exhaust brake control box. I think I have a whole $25 invested in the setup for the exhaust brake.
