Engine/Transmission (1994 - 1998) 2 wheel low HELP
I have a 2 low kit on the way, but it won't be here in time for tomorrows load that i am taking and i am up and down a particular hill that REQUIRES 2 low especially since I have a limited slip up front as well. Does anybody know which vacume line or lines that I can unhook to SAFELY run the truck in 2 low. I only need this to work for tomorrow. TIA
Jamie
here u go
I just put one on a truck last night. I think If u lfollow the vac lint on the driver side of the frame from the t case it will go up by the stater and up to the top of the fire wall rite below the hood seal. If u follow these vac lines There will be a green and a white vac line. The white on will go to a T on the fire wall. Un plug it and plug the t and plug the white line and it shoul not let the front axle ingage. This Should work. Thanks Justin.
