LESSEE...
1. Antenna(s) mount in bed on each side of fuel/tool box - fed with mini-8 coax, lead was run temporarily thru rear window slider, has since been permanently installed by running it over under driver-side seat to door sill, where hole was drilled for coax passage on back to bed of truck - no change. And I stress, this so far has only occured on 20 meters - other bands are fine. Unfortunately, 20 and 40 are my main bands of interest!
2. Radio itself is grounded directly to adjacent seat framework with large braid - coax is ferrite choked at base of whip - has been tried at other various locations, no improvement - reducing power helps, but obviously is self-defeating...
3. I have tried (as pointed out above in another post) running the radio on a totally isolated, separate battery right next to the radio on the floor, and with ferrite choked leads - no improvement! It's not RF getting directly into truck wiring thru power leads to the 706!
4. I have ferrite choked the Edge Comp - thinking THAT might be the problem - and also have several other ferrited RF chokes at other locations relative to the Comp sensor attachment points - no improvement... Makes no difference what setting the Comp is on, or even if its turned off...
I mean, all the above is COMMON stuff in troubleshooting problems of this type - *I* am WAY past "common", and am now way out in the Twilite Zone!
Matching coils/capacitors for bands below 20 meters are pretty common - not usually required for 20 and higher with proper mobile antenna design - my 20 meter antenna is perfectly flat, with SWR measured at either the base of the antenna OR at the 706. I don't rely upon merely the mechanical attachment of the mobile mount to provide RF ground, but also provide an alternate ground path via large braid directly to the bed of the truck to several bolts.
AND, I suspect that differences between a '99 and my '02 could be pretty significant as far as various specific computers, harnesses and RF is concerned. My receive situation is absolutely dead quiet - no change whether engine is running or not - and I really want to be able to eventually install my Ameritron ALS-500 solid state amp in the truck as I did in my '91 - but don't dare until I get this RFI problem eliminated - sure don't wanna blow a $1500 ECM out on some lonely stretch of highway...
Unless some more specific info comes in, I'm becoming pretty convinced the only real avenue of correction will be to totally wrap all underhood wiring in aluminum foil, carefully bonding that at various points to the body - it's not very hard to do, I've done it before with great success - but with a new vehicle still under warranty for many items not voided by my Comp, would hate to have to then REMOVE all that for some stupid electrical problem needing dealer attention...
