2000 Cummins ISC 8.3L Head Bolt Torque
Library of Congress OK's some engine software mods??
2000 Cummins ISC 8.3L lift pump question
I have an issue with a model year 2000 Cummins ISC 8.3L. While there is no measurable loss of coolant from this engine from the reservoir, and nothing seems amiss in an oil analysis, I seem to have a very small amount of coolant that likes to seep out around the back end of the cylinder head to block area. It doesn't run out, or drip onto the ground. It usually can only be seen after sitting for a few days. It's more like a film in that spot. But a couple times I've seen a few drop sized spots there on the block. It's red...so it's the coolant.
After talking with the local KW truck dealer (Cummins repair center) about this...the shop person said he'd try to "re-torque" the head bolts while it's still hot/warm and see if that stops the issue. Which I can do. But what torque do I use? I think the ISC torque sequence involves steps of ft-lbs values and a final step of advancing so many degrees. So I really have no idea what I should set my wrench to for a "torque-check".
Anybody have any suggestions?
A quick search turned this up: Since the spec is 90' past the torque value It seems you would either loosen and retorque, or just take a WAG and give them a little bit beyond where they are. Maybe 1/8 Turn? The pre-91 spec may be a clue.
Pre 1991
30ft. lbs.
111ft. lbs.
162ft. lbs.
Post 1991 – Used block and Capscrews
1. Torque all in sequence to 52ft. lbs.
2. Torque 14 Long (1,2,7,8,9,10,15,16,17,18,
23,24,25,26) to 107ft. lbs.
3. Torque Short (3,4,5,6,11,12,13,14,19,20,21,22)
to
52ft. lb. (70Nm)
4. Repeat step 2.
5. Tighten all in sequence an additional 90°.
Would that apply to the ISC 8.3L or just the C8.3L? Isn't the 1998 up ISC head different than previous C series heads?
Hmmmm, I missed that. Just found this:
Torque Value:
50 n.m [37 ft-lb]
150 n.m [111 ft-lb]
Loosen all capscrews
115 n.m [85 ft-lb]
115 n.m [85 ft-lb]
Advance 120 degrees
You may want to PM MWilson. He has been very helpful obtaining solid info for folks on here.
