The old D70 in the truck in my signature has a chipped ring gear tooth and is on the way out. Don't want the expense of buying a new ring & pinion set, then the bearings and etc. , and then having to pay someone to "properly" install everything. To me it's much more efficient to swap out the whole axel.
So what is "preferable" is an 01. 5 - 02 with disc brakes, I'm sure I've said that "I hate rear drums" on at least the TDR at least 10 times over the years so - since it's time to swap out the axel I may as well shoot for rear discs.
If all that is available is a drum break rear then that'll have to do.
My truck is an 8800 GVW and has the snowplow and camper options so I "think" the D70 that's in it now is a D70HD???
If a D70 is all that's available then it must be exact as mine.
If I should be fortunate enough to find a D80 then I'll need the U-Bolts and saddles as the tube on an D80 are larger diameter than the D70 and my old saddles won't work.
Hope someone out there has something that'll work. I'm scrounging the scrap yards around here and all I can find are *ord and *hevy junk, any Dodges I've found are either 1500s or any 2500s have been stripped of all the good stuff . . .
