2001 auto mod questions
Serpentine Belt Shifting
NEW Lift Pump a "Performance" item??????!!!!!!!
i have a 2001 ext cab long bed 4x4 auto and i put in a 14inch k&n and a new bd plug and play"VA" and got rid of the cat and put on a 3inch borla muffler with a exit before the wheel tailpipe so what should be my next mod alot of people are saying converter
thanks george
2001 auto
Gauges
I would start with the gauges next especially if you plan to go further. Lets see what all the experts say. Good luck. Dwayne( EGT, transmission temp, boost):D
One word for you..... GAUGES.
With out a doubt these are the first thing you should do to your truck.
As for the second thing, I am with the other people, add a DTT valve body and TC, you will not be dissapointed.
I like the SPA gauges, you can see one in the link in my signature.
Ice Bomb
Originally posted by **ICEMAN**
what is the ICE-BOMB??
<font color = blue>
ICE bomb = In Car Entertainment, IOW, factory Infinity system removed, Replacement High-end Alpine multimedia system installed. This is the wrong forum to elaborate here though..... should really be in P&A
... hey, good looking 2001. 5 3500 Iceman - I can recommend changing the HY35 turbo to an HX unit/12cms unit with the DD2 injectors - it would sure give your snowplow an "edge" :D:D hence the question perhaps?
Since you have an AT, I would reccommend a transmission temp. gauge as well as a fuel pressure gauge. Might as well start thinking of mod. banjo bolts while your at it. And then you might want... ... ... The list is endless. It never stops.
my trans has a factory trans temp light is that not enought thing about trans temps there is nutting u can do about them if u have a cooler thats all u can do theres no changing it
george
