2001 Dodge 3500 Ram 4X4 5 Speed Cummins Sell or Trade
For SALE : 1995 2500 ext CAB - LONG bed Auto trans
OEM Exhaust Manifold from My 1999...
Up for sale A 2001 Dodge Ram 3500 SLT Larime 4X4 built for towing
Motor 5. 9 Cummins 24 Valve, Transmission 5 Speed NV4500
Gear Ratio 3:54 with a Dana 80 Limited Slip Rear Axle
Runs Great lots of power, very quick!
All power options, leather interior, Heated Seats, Factory AM/FM Cassette with 6 Disk Changer, CB.
$15000 Performance/towing Upgrades and accessories(just parts no labor!), WITH RECEIPTS. Truck has a lot of power and reliability upgrades!
2 owner truck, same non smoking adult owner since September 2002!
Truck set up for towing heavy loads, but rarely is used.
Engine upgrades include
PDR ball bearing HX40 Turbo
DDII diamond honed and matched injectors,
ATS 3 piece Exhaust Manifold (can be upgraded to twin turbos!),
Banks Exhaust,
Banks High Rise Intake,
Fluidampr Harmonic Balancer,
FASS 150gph lift fuel pump with 2 filters
1/2 Fuel Lines, Biodiesel compatible,
Edge Comp fuel/timing box, and more!
Aftermarket Options
9000 lb. Winch, 3/4hp Air Compressor, 10 gallon air tank, remote air connect, 5000lb
Air Lift bags with in cab Controls and Gauges, DOT locomotive Air Horns X4.
Transmission upgrades @ 220,000 miles Blumenthal's NV4500 with 1 3/8 inch input shaft,
bronze and forge components and cast iron tail housing, Transmission Fast Coolers, South Bend's OFE 13" 3800 lb.
Clutch with 6 speed flywheel and SBC Stainless Steel Clutch Hydraulics, Short Throw Shifter upgrade.
Acola Forged Wheels
Rear Differential Cooler, Rear Dana 80 Axle rebuilt and reinforced @ 115000 miles,
Aftermarket Gauges include,
0-60 psi Turbo Boost (Truck Produces up to 42 PSI of Boost),
Exhaust Temp, Transmission Temp, Oil Pressure, Fuel Pressure, Air Tank Pressure, Dual Air Bag Pressure.
4 wheel disk brakes, ABS,
Goose neck/ 5th wheel hitches, Prodigy 4 axle Brake controller.
VP44 Injection pump replaced with Bosch upgraded VP44 injection pump @ 240,000 miles
2 New Interstate Batteries
New radiator and front seal
New fan hub bearing
New hoses/belts and tensioner
6 New Bf Goodrich Rugged Trail TIRES,
Darrin steering stabilizer.
Rancho 9000 shocks,
Drilled & Slotted Rotors front and rear with extreme duty brake pads.
HUGE STEEL Front Bumper with 9000 lbs. Winch
and LOTS MORE!
ALL SYNETHIC OILS USED SINCE 2002!
Last dyno hp 450 plus, over 1000 lb. feet of torque
Condition, well it's a 2001 farm work truck and has dents and dings etc.
Current miles 275k miles, driven daily.
Price $15,995. 00
Call or Text after 3pm until 9pm on weekdays, 8am to 10 pm weekends 864. 828. 0110 or e-mail @ -- email address removed --
Reason selling, bad knees, need an automatic transmission
Looking for a 2003 or newer Dodge 2500 or 3500 4X4 4 door 5. 9 Cummins with automatic, sorry not interested in any other trades.
Here are some more photos, 1st photo has the old tires on it, check out the new ones, very aggressive, but don't hear them in the cab ;)
I'd be interested in the truck if its was closer. Stuck up north unfortunately, wont be getting down that way for a while seems like. Nice truck though.
