2001 ETH oil filter
Howling Noise
New forum -- let's use it wisely.
I just changed the oil for the first time at approx 2000 miles. I had a h*** of a time getting the oil filter off. I tried two different types of wrench, both of which were the CORRECT size!!!! Finally, I did the backup thing and used the old screwdriver thru the case method. It makes a mess and it took four tries at it, but it finally came loose!! I don't know how many ft. lbs. of torque it took to break it loose but there is NO EXCUSE for putting one on that tight!!! Maybe someones idea of a joke?? Has anyone else had this problem??
2001 eth dee slt+ blk agate leather Warn transformer mount Hella 4000s Hella 530 backups Optima redtops Toro liner (Jacobs ebrake ordered-nationalback order)
The filter need to be tight to keep them from vibrating loses, but maybe not that tight.
Eric Pitts
2001 Properly Valved 2500 Qcab 4X4 auto 4. 10 LSD Prime-Loc
Weston Nerf Bars Smith built brush guard
Command Remote Starter
Neophyte B. O. M. B. er
Terre Haute Indiana
The Pitts Home Page
Member GLTDR
Be xtra cautious when you let the can drop down on all those wires. My Dealer said there is going to be a TSB issued concerning do-it-yourselfers:1. Some folks are moving the AC line, under the can, next to the turbo intake and the AC connector is rubbing a hole thru the intake piping. 2. Some folks are letting th can hit the hot wire on the alternator and blowing a fuse. No more battery charge. He advised putting a towel under the can before letting it drop down--also don't try to ge a whole quart of oil in the new can. Fill it to the top once and let it drain down-and that's enuf oil.
99' Stock Quad 4x4 A/T LB 3. 54 30K Miles.
Did have both 18-11-99 & 18-08-99 TSB's performed.
Pull a 7000# Terry 26H TT over, around and thru the Cascades.
Founder/President of the: KISS MY DIESEL CLUB. Club Motto: "There's a sucker born every minute. "
beartrack,
When I did my oil filter change for the first time I had the same problem also, I almost broke my strap wrench. I finally got it off with the strap wrench connected to a 2 foot breaker bar. I definately think they put the filters on too tight. I was thinking I might mess up the threads on the engine trying to get the old filter off.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, air dam, 4w ABS, camper and trailer tow packages, fog lamps, CD/cassette, HD transfer case, snow plow prep, travel convenience group, cab lights (ordered 1/11/00, shipped 2/14/00, recieved 3/4/00).
5000 miles as of 4/10/00.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
Changed my oil last week at 5200 miles and I had the opposite problem. Filter and drain plug were hardly tight at all.
I think I like the drain plug. Just loosen it 2 turns and it will drain the crankcase in about 5 minutes.
You should remove it all the way so any slug or bits of metal can wash out.
2001 2500 ETH/DEE Blk/Agate 4x4 QC LWB SLT+ 3. 54 LSD, Every option except Snow Plow and Cab Lights. 12000 lb Warn Winch and all the right gear.
Strap wrench is the way to go. I use a simple rule for tightening the filter. On the Mopar filters (Yuk), if the "A" if facing you, turn it until the "C" is facing you. Otherwise I just make a mark about 1/2 to 3/4 of the way around after finger tight and tighten til it faces me. Hope that helps.
I like the oil filter pliers as sold by Griot's Garage (www.griotsgarage.com), Snap-On, Wal-Mart and others. These are nothing more than a large pair of specialty slip-joint pliers. There is NOTHING out there that can remove your oil filter faster. I install the new filter after priming with one quart of oil and lubricating the sealing gasket, HAND TIGHTENING 3/4 of 1 turn after the gasket contacts the mounting surface. I also apply a reference mark on the new filter that aligns with a mark I previously made on the mount to detect any possible loosening tendencies, while performing other routine maintenance or BOMBing operations.
NOTE: Be very careful how you reference the 3/4 turn after oil filter gasket contact with its mount as the Fleetguard label appears twice on the filter case, once right side up, the other inverted. If you use the label as a basis for tightening, this can cause improperly tightened filters if strict attention is not paid.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, Reese Titan V hitch, plus many other trick modifications
[This message has been edited by John (edited 05-24-2000). ]
