Archived 2001 missing
Archived Truck died on road.
Archived Help - Coolant Blowing out of Catch Tank
truck started ok and drove fine for about 15 miles, then it all started :eek: engine started missing , i pulled over and shut it off to check a few things ( drain fuel bowl,replaced filter 4 days ago,also to check IAT sensor replaced 3 days ago) everything looked ok . i started the truck up, it was a smooth idle returned to the road and around 2000 rpm it started missing again , pull off at a dodge dealer i know bad idea but i am out of town working. please help:confused:
Exactly why I am going to heed warnings from others and install a fuel pressure gauge very soon.
I am not a expert by an means, but many times I have read that the fuel pressure is steady at lower delivery rates, then falters as the RPMs increase, lift pump maybe. ??
JJ
You have 275s so you would see a fuel related problem pretty quick. Have you had your lift pump replaced before? You should get your pressure checked. I hope this is not another VP44 about ready to melt.
