2002 Quad Cab, 4x4, shortbed, HO, 6-speed
oil filters and fuel filters for sale
Wanted Transfer Case
$17,500
as delivered
2002 Dodge Ram 2500 HO purchaced new 12/15/2001
Quad Cab 139" wheel base
VIN# 3B7KF23C92M224456
High Output motor (ETH)
NV 5600 manual transmission (DEE)
factory towing package - class IV receiver hitch
exterior - almond light metalic pearlcoat, interior - camel/tan cloth
condition
137350 miles as of Nov/03/2018
Complete mileage, service, alteration records, factory service manual
no rust, no dents, paint is sun worn
engine and drivetrain
Southbend ConOFe Clutch
BD Short Shifter
Bob V's Deluxe 2-Wheel Low Kit
Exhaust Brake (Jacobs) - switch on shifter
4" Magnaflow Exhaust
F1 Mach 1.6 85HP injectors (stock HO injectors included)
Fuel Preporator - Air Dog
ISSPRO pillar-mounts gauges - fuel pressure, boost, exhaust temp
Amsoil oil bypass kit
new Blue Chip Diesel VP44 - premium pump x17 (5/5/2018)
silicon air and water hoses
new (reman) ECU (8/17/2018)
new clutch hydraulics (master/slave cylinders, reservior, and lines) (11/3/2018)
relocated crank case breather
steering and handling
Tires - (5) Goodyear Wrangler Trail Runner LT265/75R16E (3/10/2017)
lower ball joints replaced (04/12/2017)
replaced headliner and visors in 2016
Borgeson steering box
Borgeson steering shaft
Rock Solid Steering Bushing
replaced tie rods and drag link with T-style heavy duty and steering dampner
G3 trackbar kt (DSS)
DSS (Darin's Steering Stabilizer)
Maxx Link heavy duty swaybar links front & rear
Bilstein Shocks
accessories
50-gal in-bed TransferFlow Fuel tank w/TRAXII controller
ARB Sahara Bull Bar
IPF lights with "high-beam" floor switch and indicator light on pillar
Viair Air compressor and tank with in-cab gauge and pressure switch
Air horns (22 & 24-inch) - switch on shifter
Mag-Hytec rear diff cover
Jordan Brake Controller
Painless Wiring Kits #70207 (2) (all electrical accessories are fused & relayed)
Smittybuilt Wheel-to-Wheel step bars (with spare step pads)
passenger's side bed step, front and rear bumper steps
Noise Reduction - triple sprayed cab and hood
Alpha-Liner bed lining
Swing-away storage box in bed
tailgate pop-a-lock
Truxedo tonneau cover
Mud Flaps
2 under-seat locking boxes
Dashmat dash cover (since new)
extras
MAD's Smarty ECM is currently stock and the MADs unit should not be VIN-locked
5th-wheel tail gate, Handy, steel, black (not installed)
BHAF Heat Shield (not installed)
BHAF - Fleetguard AH19037 (not installed)
picture gallery on SmugMug:
https://winnemore.smugmug.com/frame...transition=fade&transitionSpeed=2&clickable=1
