2003-2024 Ram Heater Core Replacement Hose & Fitting - from Fleece Performance
Drop-In Fuel System for 2010-2018 Ram - from FASS
TDRComm
Staff Member
HEATER CORE REPLACEMENT HOSE AND FITTING FOR 2003-2024 RAM 5.9L & 6.7L CUMMINS
Heater core maintenance is one of the most time consuming and difficult jobs known to service technicians and DIY mechanics. If this is a job you have to do, do it once and do it with the best replacement parts. Fleece Performance’s hose and fitting kit will eliminate the troublesome and leaky quick disconnect heater core line on your 2003-2024 truck.
This stainless-steel riser and silicone hose kit are a direct replacement for the problematic stock hose and riser, giving you a reliable solution to fix heater core/plumbing leaks. Permatex thread sealant and two new hose clamps are included with the kit.
This kit (part number FPE-CUMM-HCL-0324) is a direct replacement for the following part numbers:
• MY 2003-2007: Gates 19168
• MY 2007.5-2010: Gates 18774, Mopar 55056711AC
• MY 2010-2012: Mopar 55056966AA
• MY 2013-2018: Gates 23957
• MY 2013-2024: Mopar 52014739AG
APPLICATIONS: 2003-2024 Dodge Ram Cummins 5.9L and 6.7L 2500/3500/4500/5500
Part Number: FPE-CUMM-HCL-0324
Price: $69.99
Available at Geno's Garage: www.genosgarage.com
Manufacturer Contact:
Fleece Performance 2400 Commerce Way
Pittsboro, IN 46167
www.fleeceperformance.com
