2003 Headlight control module
Where is the heat?
Right Front Door won't Release
Is it possible to get away from the front control module? If all it does is contorl the lights then it might be possible bypass all this faulty electronic crap.
Lets see, head lights, low/high beams, turn signals, wipers, wiper delay, dome lights, cruise control, and what else have I missed.....
It's like asking your engine to run without the ECM.....
i just bought a new fcm for 39 dollars from chrysler parts direct, the local dodge dealer wants 230 and e-bay wants 89 and some used parts dealer wants 330 ???, the service manual says remove the integrated control unit to get the fcm out, but all you have to do is remove the left head light and all four screws are right there, quarter inch drive ratchet and a seven millimeter shallow socket, to remove the headlight you will need a 10mm socket and a phillips screw driver and long extension.
Jwadford, do you have a part number for what you ordered? I think I'm in the same boat here, and am up against a wall. One dealer is telling me $2000 for a new power distribution center...
Thanks,
Chris
