Archived 2003 Lots of codes runs like Crap???
Archived Help! 12 valve won't start
Archived Radiator
I have this 03 3500 single wheel truck has 125k miles on it truck was running great untill about a week or so ago the injectors started to hammer very loud truck is all stock but it still run really good the noise would kill you though. . I just bought 6 new reman injectors from Dynomite and installed them today and the truck runs very bad now I also put a Airdog Raptor pump on it that I had bought last week as well I have put like 80 miles on it since the injectors and I mean it runs really bad it will loose speed on the slightest little hill in 5th or 6th its bad. The codes in the truck are 0234,0237,0628 there is a couple of them that are in there 2 times?? I have checked and doubled checked everything and have no idea. . Thanks TJ 573 426 5199
TJ,
Have you tried replacing the MAP (boost pressure) sensor? DTC's P0234 and P0237 indicate a failed MAP sensor.
DTC P0628 is usually related to lift pump failure, but since you've installed a new pump, that just could be an old code left over.
Try replacing that MAP sensor.
John L.
I just took the map sensor off of another truck and tried it and the same thing no diff. . I have no Idea I have been looking all over the net and cant a thing. . Thanks. . I do have a donor truck here to try and switch parts. .
Fixed the truck!!!!!!!
Well we got the truck fixed and it was the crossover tubes in the head not alinged up right what a deal but we are very happy its fixed. .
That seems to be a more and more common problem now that more are changing injectors. Was there a gross error? Or are they that finicky?
They are just finiky I was told by Dynomite Diesel that they have had several people have this problem and it fixed it so we tried it and it fixed it. . Good bunch of guys out there in Washington. . TJ
