Filled with fuel last night on the way home. Ran fine for the 6-7 miles after fillup but does not start / will start but not continue running) today.
Over night low was around 15F, high temp now is mid 20's. Truck was not plugged in. Pretty sure it's "just" a bad batch of fuel, maybe water in it? No codes set.
Changed fuel filter, drained out everything in the bowl. Filter was pretty dark, but no worse then I remember the previous filter being (7-8K ago).
I added a treatment of Chevron Delo diesel stuff (only thing available in this area on a Sunday) to the tank, but that obviously can't do any good if it doesn't get circulated around. If I let it sit for a bit it will try to start, sometimes even runs for 20-30 seconds, then stalls.
What are the options to thaw this thing out? Have no inside parking available. My only thought is to go out an buy a couple heat guns and park them under the tank and fuel lines for a few hours. Or maybe a 500watt flood light?
